sdog1010
Jan 24, 2023Guide
XR1000 dumaOS not loaded yet
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help? Firmware Version: V1.0.0.64_1.0.49
sdog1010
Jan 25, 2023Guide
as stated above im using netgear CM1000v2 modem instead of an ISP provided one
Jan 25, 2023Guru - Experienced User
Ah got cha, early here. Off to get some hot tea.
Reset should get you going.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
