Zordrak's avatar
Zordrak
XR1000, Dumaos not loading
Hi,
Just picked up a second hand XR1000. Went through factory reset all fine (other than serial number already registered) But when i login to 192.168.1.1 the DumaOS page sits spinning at this page. DumaOS
running XR1000 1.0.0.64_1.0.49
Any idea's have done 2 factory resets still the same, doing this on multiple browsers and doing this via hardwired connection on laptop.
trying my best to not return etc and fix at this time of year.
  • Just wanted to say, got this working woth a TFTP firmware update and leaving it a good 10mins to fully bootup etc.
    Just now fingers crossed a newer firmware will show hybrid VPN in future.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      That's great to hear, thanks for the update, well done on resolving it.
