JrThePilgrim
Mar 05, 2024Follower
Xr1000, DumaOS ping heatmap and connection benchmark not working
Ive been having issues with lag in game, when I went in to DumaOs the Heatmap wont let me ping, Ping isnt even an option for me to click its a dull red, connection benchmark loads but then does nothing been at this for about 3 hrs now. HELP ME!!!!! rebooted router, factory reset router, turned anything off in multiple browsing apps that could be causing the issue.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What browser is being used? Try MS Edge or Firefox?
- Netduma-FraserNetDuma PartnerJust to double check is the WAN/internet port of the XR connected to a LAN port on your ISP modem/router? Usually this happens when they haven't been connected together properly
