Ggpxj's avatar
Ggpxj
Guide
Jan 06, 2023
Xr1000 dumaOS
Geo filter and ping heatmap will not load. Geo filter says uncatch unedified before saying rapp not loaded yet .Ive factory reset my router cleared cookies anything i could think of.
  • Could you provide a screenshot if possible of the exact error prior to the Rapp not loaded message? What firmware are you on currently? How did you do the factory reset?
    • Ggpxj's avatar
      Ggpxj
      Guide
      I believe i just erased logged back in.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Make sure your browser isn't forcing HTTPS which quite a few do now and force yourself to connect via HTTP to the interface and see if that disappears then please
