Ggpxj
Jan 06, 2023Guide
Xr1000 dumaOS
Geo filter and ping heatmap will not load. Geo filter says uncatch unedified before saying rapp not loaded yet .Ive factory reset my router cleared cookies anything i could think of.
Ggpxj
Jan 08, 2023Guide
I found this...
Netduma-Fraser
Jan 08, 2023NetDuma Partner
Enter edge://flags/#edge-automatic-https in the browser and press enter, then see if it's set to disabled
- GgpxjJan 08, 2023GuideOk it was set to default. So do i disable?
- Netduma-FraserJan 08, 2023NetDuma PartnerYes disable it then try to access again
- GgpxjJan 08, 2023GuideAlso getting nissing json response.
- GgpxjJan 08, 2023GuideSame thing. Not working
