Ggpxj
Jan 06, 2023Guide
Xr1000 dumaOS
Geo filter and ping heatmap will not load. Geo filter says uncatch unedified before saying rapp not loaded yet .Ive factory reset my router cleared cookies anything i could think of.
Netduma-Fraser
Jan 10, 2023NetDuma Partner
Re-install the latest firmware, then after a few minutes perform a factory reset, that should give you a clean install and see if it has gone then please
Ggpxj
Jan 10, 2023Guide
GOT IT! Installed the older version. Factory reset. Installed newer version. Its running well now.
Thanks alot! Its been really stressful.
