FED1920
Jun 04, 2023Tutor
[XR1000] eFootball Geo-Filter
Hello, When I'm playing on eFootball game by filtering out a specific server (the belgian one), I'm still forwareded to that server which is not set on my autorized zone on the GeoFilter. The ga...
- Jul 02, 2023Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then you should see icons on the map again. Then trying allowing the server that you're seeing outside the range.
Netduma-Fraser
Jun 05, 2023NetDuma Partner
Most likely you have strict mode disabled (you need it enabled) or you have Ping Assist enabled (needs to be set to 0 to force specific servers).
- FED1920Jun 05, 2023Tutor
Strict Mode is enabled and Ping assist disabled, and still have this issue
- Netduma-FraserJun 05, 2023NetDuma PartnerCan you provide a screenshot of what you're seeing on the map when you're getting that server please?
- FED1920Jun 08, 2023Tutor
