FED1920
Jun 04, 2023Tutor
[XR1000] eFootball Geo-Filter
Hello, When I'm playing on eFootball game by filtering out a specific server (the belgian one), I'm still forwareded to that server which is not set on my autorized zone on the GeoFilter. The ga...
- Jul 02, 2023Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then you should see icons on the map again. Then trying allowing the server that you're seeing outside the range.
Netduma-Fraser
Jun 09, 2023NetDuma Partner
Okay so that's a good thing, how is it not working now exactly?
FED1920
Jun 09, 2023Tutor
I prefer the previous situation when the game is voided when the matchmaking is done one a blacklisted server.
Now when the matchmaking is confirmed, the yellow icon of blocked server disappear from the GeoFilter page and the game start with a horrible latency making the game unplayable for me.
- Netduma-FraserJun 10, 2023NetDuma PartnerThere should be an icon showing on the map when you're in a game, you may need to zoom out, can you see one?
- FED1920Jul 02, 2023Tutor
Yes I see it, but since few days the Geo-Filter page is not displayed anymore...
- Netduma-FraserJul 02, 2023NetDuma PartnerTry this:
Wait 2 minutes
