FED1920's avatar
FED1920
Tutor
Jun 04, 2023
[XR1000] eFootball Geo-Filter
Hello,   When I'm playing on eFootball game by filtering out a specific server (the belgian one), I'm still forwareded to that server which is not set on my autorized zone on the GeoFilter. The ga...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jul 02, 2023
    Try this:
    Quit the application/game/client completely
    Remove device from the Geo-Filter
    Give PC PlayStation Device Type in the Device Manager (if on PC)
    Resync from the Geo-Filter Map menu
    Re-add the device to the Geo-Filter with the manual option
    Set up the Geo-Filter how you like
    Wait 2 minutes
    Boot up application/game/client
    Then you should see icons on the map again. Then trying allowing the server that you're seeing outside the range.
