basilverthorn
Nov 06, 2025Tutor
XR1000 Enabling VPN service stops internet / DNS from working.
Items I have tried: (more than twice each) reflashed firmware Factory default through web browser Factory default using reset button Created VPN on differnt ports using UDP All three options fo...
- Dec 24, 2025
Yeah thank you, I left netgear. Went to Ubiquiti and so far life is great. It all works as it should, even better. Thank you for the reply take care, to many bugs, to long of a wait.
Nov 11, 2025Guru - Experienced User
basilverthorn wrote:The setup is as follows:
- Enable DHCP
- Enable ddns
- Enable OpenVPN server
I am thinking this is with the PiHole running.
If so, I am wondering if you get the same behavior if you take the PiHole out of the equation.
