basilverthorn
Nov 06, 2025Tutor
XR1000 Enabling VPN service stops internet / DNS from working.
Items I have tried: (more than twice each) reflashed firmware Factory default through web browser Factory default using reset button Created VPN on differnt ports using UDP All three options fo...
- Dec 24, 2025
Yeah thank you, I left netgear. Went to Ubiquiti and so far life is great. It all works as it should, even better. Thank you for the reply take care, to many bugs, to long of a wait.
basilverthorn
Nov 11, 2025Tutor
Yes same behavior, I had retired my pihole servers and moved to nextdns for adblocker as my family hated the piholes after a few years ;-). I only brought the Pi-Holes back to assist due to this issue, and thankfully it resolved it. But id like to move my PI's back to running klipper for my printers.
