basilverthorn
Nov 06, 2025Tutor
XR1000 Enabling VPN service stops internet / DNS from working.
Items I have tried: (more than twice each) reflashed firmware Factory default through web browser Factory default using reset button Created VPN on differnt ports using UDP All three options fo...
- Dec 24, 2025
Yeah thank you, I left netgear. Went to Ubiquiti and so far life is great. It all works as it should, even better. Thank you for the reply take care, to many bugs, to long of a wait.
ross8888
Nov 11, 2025Aspirant
Hey! That setup can really mess with the XR1000’s DNS, PiHole working shows it’s a router-side issue. A quick fix is forcing DNS in the LAN settings or tweaking OpenVPN’s pushed DNS. Long-term, keeping PiHole for DHCP and letting the router just handle routing seems to be the smoothest solution.
avalynn
Nov 12, 2025Tutor
Hey! Spot on — PiHole stepping in proves the XR1000’s DNS proxy is the weak link when OpenVPN and DHCP team up. Forcing external DNS (like 8.8.8.8/1.1.1.1) in LAN Setup or via OpenVPN’s Push DNS usually patches it quick. But yeah, the cleanest long-term win is letting PiHole own DHCP — router just routes, VPN runs happy, no more silent crashes. Solid workaround till Netgear squashes the bug.
