Christiaan11
Sep 26, 2022Apprentice
XR1000 error
Hi all, Since a while I have the Nighthawk XR1000. Overall I'm disappointed of what it can do but that's another discussion. since a while I now have the error below. I thought it was just an w...
- Sep 26, 2022Okay so Safari forces HTTPS which is why you will have been getting those errors, the interface works best through HTTP.
Try this for the Geo-Filter:
Quit game back to the console dashboard
Remove device from the Geo-Filter
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up game
Then see if it works better.
Sep 26, 2022Guru - Experienced User
What browser are you using? Happens in different browsers?
Christiaan11
Firmware is the following: XR1000 1.0.0.64_1.0.49
The modem it's connected to is a Connectbox Giga / Eurodocsis 3.1 modem from Ziggo in Netherlands.
I have to say at the start I didn't have this issue at all. It started to occur later.
Thanks!
