Christiaan11
Sep 26, 2022Apprentice
XR1000 error
Hi all, Since a while I have the Nighthawk XR1000. Overall I'm disappointed of what it can do but that's another discussion. since a while I now have the error below. I thought it was just an w...
- Sep 26, 2022Okay so Safari forces HTTPS which is why you will have been getting those errors, the interface works best through HTTP.
Try this for the Geo-Filter:
Quit game back to the console dashboard
Remove device from the Geo-Filter
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up game
Then see if it works better.
Netduma-Fraser
Sep 26, 2022NetDuma Partner
What pages is this error appearing on specifically? What web browser/device are you using to access? Are you using Armor? Could you expand on what you mean by the Geo-Filter isn't working - is it showing an error?
Christiaan11
Thanks for the reply.
- Error is showing on each of the DUMA UI pages in the web interface. The regular settings I can access without an issue.
- When I get the error I click OK and can interact with the interface.
- I'm using Safari browser on Mac.
- Geo filter isn't working as I used to see it connect to servers in the Duma UA. Now while gaming it stays blanc. I removed the profile and added my PS5 again but it is still not working.
- I'm not using Armor. I do have the license, but when I tried to turn it on using the app it gives me a time out.
- Christiaan11Sep 26, 2022Apprentice
Ok, switching to Chrome solved the TypeError issue. Maybe it's a cache thing in Safari. Will have a look!
GeoFilter however is still not working. Will looking for a game no servers show up while it is connecting to one on my PS5. I did remove and add the profile again in Chrome.
- Netduma-FraserSep 26, 2022NetDuma PartnerOkay so Safari forces HTTPS which is why you will have been getting those errors, the interface works best through HTTP.
Wait 2 minutes
Boot up game
Then see if it works better.- Christiaan11Sep 27, 2022Apprentice
Thanks again for the tips. I did all that but unfortunately it's still not working. No servers are showing up on the interface.
