XR700_Fan
Jan 08, 2021Tutor
XR1000 Firmware 1.0.0.52 broke all twitch streams to every device.
I had to go back to 1.0.0.50 and disable automatic firmware update. We spent around an hour and a half diagnosing this, with the kids losing it go figure.
I forgot to say that I am fairly sure it had something to do with Netgear Armor.
- Netduma-FraserNetDuma PartnerThere is nothing that we (Netduma) have specifically changed in that version at all so that is very weird behavior. Is that the only thing you can see that was affected by the upgrade? You can disable Armor using the Nighthawk app to see whether that does fix it.
