Devildog0321
Sep 02, 2022Aspirant
XR1000 firmware update stuck
Trying to update to latest firmware on new XR1000 so far I’ve waited for 45 minutes. Don’t want to interrupt the update but what my options?
Devildog0321
Using hardwire connection to router from laptop on Firefox. Finally shut router off and rebooted it. Can logon to router and see Firmware did not update.
Netduma-Fraser
Sep 02, 2022NetDuma Partner
Did you do the update by uploading the file manually or allowing the router to check for firmware and let it download and install?
