Daryo89
May 02, 2022Aspirant
XR1000 fresh installation and speed capped
Good Afternoon, I changed my network node from x4s r7800 to xr1000 and I am currently stack with a capped speed of 140Mbps download and 118Mbps upload for all device and subnetwork connected to the X...
Daryo89
speetestSpeedtest on XR1000
Result from fast.com
Result identical in WIfi and Lan connection from laptop
Netduma-Fraser
May 02, 2022NetDuma Partner
We can't see your pictures until moderated, could you attach them directly or link to them? How did you disable QoS exactly? Can you unplug the PC from the hub please as that can draw bandwidth away from the router. How is the hub setup to pass traffic to the XR? Can you provide a screenshot of the table view of the Device Manager on the XR please?
