Barry_M
Nov 04, 2022Tutor
XR1000 geo filter, ping heatmap, connection benchmark, QoS issues
Hello, recently been having some issues with my router, wondering if anyone has had similar issues and how to fix. Ping heatmap (no games show any servers at all, doesn't allow me to ping again eith...
Netduma-Fraser
Nov 05, 2022NetDuma Partner
This sounds like you need to do a factory reset, if you didn't do one after updating that will be why they're not working correctly
- Barry_MNov 08, 2022Tutor
I have tried factory reset already, after reading through the forums the only way i was able to use these functions is by using 192.168.1.1, However Ping Heatmap and Geo Filter seems to have stopped working now and just times out saying to wait briefly to using this raps again.
i have tried routerlogin.com and routerlogin.net both same issue.
- Netduma-FraserNov 08, 2022NetDuma PartnerGo to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
I did those steps and it is now working on 192.168.1.1 but not on the "routerlogin.net/com" I'll just use the 192 to login instead, let me know if you find a fix for the routerlogin pages, Thanks for the quick reply
