paul5680
Oct 05, 2022Aspirant
Xr1000 GEO filter Uncaught SyntaxError: Invalid or unexpected token
Uncaught SyntaxError: Invalid or unexpected token OK
Oct 05, 2022Guru - Experienced User
Not much to go on.
What browser are you using? Seen in other browsers?
Be sure to clear out ALL browser caches before entering the routers web page.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
