Rel1217
Oct 17, 2022Aspirant
XR1000 GeoFilter RPC Error
I just bought the XR1000 router to hardwire my Xbox Series X to. After installation and setup, I downloaded the newest 1.0.0.64_1.0.49 firmware and factory reset. All of the apps work except for ...
- Oct 28, 2022
Hi guys,
Just wanted to follow up on this. I apologize for the delay in response. I was out of town for the last week and not able to try this.
Last night I tried to play an online game with my Xbox Series X and I couldn't connect to online MP. I checked the multiplayer connection and was told I couldn't get a teredo IP address. I did some digging and someone mentioned activating the IPv6 setting on the router fixed their issue. So I activated mine using the Auto Connect setting. Once that was activated and I restarted the router, the error disappeared for the Geo-Filter.
So I never did the manual upload of the new firmware but this did seem to solve for the error. Not sure if that makes sense or something just reset itself in the time I was gone but things seem to be working now.
Thank you guys for all your help and troubleshooting!
michaelkenward
Oct 18, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
