Rel1217
Oct 17, 2022Aspirant
XR1000 GeoFilter RPC Error
I just bought the XR1000 router to hardwire my Xbox Series X to. After installation and setup, I downloaded the newest 1.0.0.64_1.0.49 firmware and factory reset. All of the apps work except for ...
- Oct 28, 2022
Hi guys,
Just wanted to follow up on this. I apologize for the delay in response. I was out of town for the last week and not able to try this.
Last night I tried to play an online game with my Xbox Series X and I couldn't connect to online MP. I checked the multiplayer connection and was told I couldn't get a teredo IP address. I did some digging and someone mentioned activating the IPv6 setting on the router fixed their issue. So I activated mine using the Auto Connect setting. Once that was activated and I restarted the router, the error disappeared for the Geo-Filter.
So I never did the manual upload of the new firmware but this did seem to solve for the error. Not sure if that makes sense or something just reset itself in the time I was gone but things seem to be working now.
Thank you guys for all your help and troubleshooting!
Oct 18, 2022Guru - Experienced User
Ok. Good to know.
Use the LAN for the ethernet connected PC.
Be sure you do a full on factory reset and setup from scratch. Do not re-enable Armor at any point.
Rel1217
Oct 28, 2022Aspirant
Hi guys,
- Netduma-FraserOct 28, 2022NetDuma PartnerInteresting, glad to hear it is resolved and thanks for posting the solution!
- FURRYe38Oct 28, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
