Rolex
Nov 12, 2021Tutor
XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
I have been trying to use GeoFilter on my newly purchased XR1000 router through DumaOS and it will not open. Firmware version 1.0.0.58 Any suggestions would be appreciated.
Netduma-Liam
Nov 16, 2021NetDuma Partner
Thanks for posting this issue.
Which browser are you using to access the interface? Are you seeing the same problem in all web browsers?
If you reboot the XR, are you then able to access the interface again until the problem re-occurs?
- RolexNov 16, 2021Tutor
I have used both Gooogle Chrome and Firefox. I have also rebooted the XR as well and can use the interface. I just cant access the GeoFilter.
- Netduma-LiamNov 16, 2021NetDuma Partner
Thanks for letting me know!
So could you please go to System Information -> Installed Rapps -> Click the three line menu -> Set the number of retries to 5. After this you may want to reboot the router, then see if Geo-filter will load.
- RolexNov 17, 2021Tutor
I followed your steps specifically and still not luck.
