Rolex
Nov 12, 2021Tutor
XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
I have been trying to use GeoFilter on my newly purchased XR1000 router through DumaOS and it will not open. Firmware version 1.0.0.58 Any suggestions would be appreciated.
Rolex
Nov 16, 2021Tutor
I have used both Gooogle Chrome and Firefox. I have also rebooted the XR as well and can use the interface. I just cant access the GeoFilter.
Netduma-Liam
Nov 16, 2021NetDuma Partner
Thanks for letting me know!
So could you please go to System Information -> Installed Rapps -> Click the three line menu -> Set the number of retries to 5. After this you may want to reboot the router, then see if Geo-filter will load.
- RolexNov 17, 2021Tutor
I followed your steps specifically and still not luck.
- Netduma-FraserNov 17, 2021NetDuma PartnerHow long are you waiting after a reboot to access? It's a good idea to wait at least 2 minutes as it gives the Rapps time to load correctly.
Okay I did that. I even restarted my pc. A new error message came up and said "Uncaught and Undefined", the preceded to go back to the original message. After I clicked ok, it went into and infinite loading screen.
