Rolex
Nov 12, 2021Tutor
XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
I have been trying to use GeoFilter on my newly purchased XR1000 router through DumaOS and it will not open. Firmware version 1.0.0.58 Any suggestions would be appreciated.
Netduma-Fraser
Dec 21, 2021NetDuma Partner
I think the best thing to do would be to reinstall using TFTP and follow the method I posted here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR1000-GeoFilter-quot-The-Rapp-is-not-loaded-yet-please-try/m-p/2165978/highlight/true#M27760
It's something persisting through resets so that is the best chance to resolve the source of the issue
Shadeaux
Jan 01, 2022Star
So, some more bizarre behavior. After doing the previous reset steps, my router started throwing a config not read error (white page with error) whenever trying to go to router login.net...even after restart.
I had not had a chance to reset again and since the actual internet was working, it wasn't a pressing need.
However, last night, while watching Hulu through the wifi connection, suddenly all wifi devices stopped connecting to internet, and when I looked at network connection options in my iPhone, I saw that my network was broadcasting the default Netgear SSID, instead of the name I had set. Stange indeed...
I could connect to that SSID, with iPhone/iPad, but it said not secured and didn't actually work.
So, I reset router with switch on back of router...AGAIN.
After the setup completed, all the RAPPS were working, and fast, including Geofilter and Heat Map.
I don't know how long it will stay working, and it was very strange for the SSID to change WHILE I WAS USING IT.
Buggy.
