Sionrai
Feb 01, 2022Aspirant
XR1000 Guest Network Broadcasting
Has anyone run across an issue where you specify that the router should not broadcast the Guest Network SSID on the 2.4GHz band but it still does? Hiding the SSID for the regular wireless network...
Sionrai
Previous photos did not upload.
RegularGuestAvailable Networks
Netduma-Liam
Feb 01, 2022NetDuma Partner
I can't see the photos unfortunatley, they're yet to be moderated.
I believe if you add them as attachments I should be able to see them straight away.
