SillyMo
Apr 30, 2021Tutor
XR1000 haserl CGI Error
Hello! I have an XR1000 that throws the following message when I try to log in to the admin page after rebooting the router. haserl CGI Error Failed to readline from 'config get DumaOS_Theme_V...
patrickbedgood
Jun 03, 2021Apprentice
Yes and specifically when you enable "Anywhere Access". There could be a situation when you are away from your home and you need to access the router and reboot it. If I reboot this new router outside of my home or even connected locally inside my home, the router loses its configuration completely. I am interested in learning how to apply the firmware update via TFTP. Did you see my error message I reported when following these steps?
1.) Unplug all network connectons from router except for dedicated static IP to PC or laptop
2.) Power off router, wait 10 seconds.
3.) Power router back on, when you see the orange light and flashing, execute PUT button on TFTP client
Netduma-Fraser
Jun 03, 2021NetDuma Partner
I'm unsure when you're seeing that error exactly, is it when you execute step 3? Try doing so using Windows TFTP instead https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Does it reset if you reboot accessing the interface via a PC?
- SillyMoJun 03, 2021Tutor
Do yourself a favor and return this POS. I've gone through 2 XR700s and now 3 XR1000s. They all exhibit the same DNS issue that Netgear has been working on for more than a year. The config issue you are running in to, is also a known issue that Netgear hasn't fixed either.
- patrickbedgoodJun 03, 2021ApprenticeWill a replacement resolve or move away from this model router?
- Netduma-FraserJun 03, 2021NetDuma PartnerThe haserl error should be resolvable via TFTP, if not then a replacement should resolve it yes
- patrickbedgoodJun 08, 2021ApprenticeOk,
So thank you for recommending I return my XR1000, received my replacement today and I tested rebooting via the mobile app and the router kept my config after the reboot. - Netduma-LiamJun 09, 2021NetDuma Partner
OK thanks for letting us know, give us a shout if you need any further assistance.
- patrickbedgoodJun 09, 2021Apprentice
Will do!
Thank you
- patrickbedgoodJun 11, 2021ApprenticeHas anyone noticed the DNS flaws in the XR1000 series? If the router reboots, it will not keep each device hostname that you set and save, instead it renames the devices jibberish!
- SillyMoJun 11, 2021Tutor
Yup. The whole XR line is plagued with issues.
- Netduma-FraserJun 12, 2021NetDuma Partnerpatrickbedgood is this happening if you reboot the router from the interface?
- patrickbedgoodJun 13, 2021Apprentice
I just received ths new router 2 days ago, gues what error message I received this morning when trying to login to the router?
haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
I have a feeling I need to try and return router to best buy and go back to my AX3000 series, just a dissapointment!
- Netduma-FraserJun 13, 2021NetDuma PartnerHad you updated or changed any settings specifically yesterday? If you reboot the router does that resolve the error.
- patrickbedgoodJun 13, 2021ApprenticeNo changes at all, just wanted to login via web this morning to take a look at some connected devices and could not login due to that error, cleared cache in all web browsers and same error. So, I rebooted router from the mobile app because it was still working and upon reboot, the router reset its config back to factory defaults again. I’ve been through this process so many times already so I’ve just removed the router and installed my AX3000 NightHawk back. I’m returning this router for refund, appreciate all the help along the way but another user on the community mentioned he had same issue and ended up returning 3 devices to Netgear.
- patrickbedgoodJun 13, 2021ApprenticeHow can I return for refund back to Best Buy since I have new serial number?
- Netduma-FraserJun 13, 2021NetDuma PartnerSorry to hear that, you would need to consult with Best Buys return policy regarding that
I called NetGear and they only allow exchange of router. I will try Best Buy, their original return policy was 15 days but now that I have this new serial number, I've only had this new router since Tuesday 6/8/21. Maybe Best Buy will honor or allow me to exhange for another router model. Thanks again
- jhdez317Jun 14, 2021Tutor
I had this same issue a month ago with myu XR500 which i had without issues for about 1 and a half years then i started getting very very bad connection, after doing the factory reset i would set my admin/password and try to log in immediately after to configure it and the:
error would come up, so I upgraded to the XR1000, it has been about a month and a half, i am getting 2.4ghz speed of 0.8mbps and 5ghz speed of above 100mbps at the second floor of my house, so i came downstairs and tested again with only slightly better results (i have 1gbps internet speed). When i tried to adjust the settings I got the same error:
I think this duma thing is just bad, im going to return the router and get a Linksys or the ROG. Absolutely disappointed, what a waste of $350, luckily i am within the return period. I'll never use a netgear product again.
- Netduma-LiamJun 15, 2021NetDuma Partner
Sorry to hear of your experience and feelings towards the XR1000 - did you try fully disabling QoS from the three-line menu in Congestion Control and re-test the speeds? If you'd like to troubleshoot this issue please let us know and we'd be happy to help.
- patrickbedgoodJun 15, 2021ApprenticeYes
Apologies, that was in response to jhdez.
What did Best Buy say in regards to your return?
- patrickbedgoodJun 15, 2021ApprenticeThey are allowing me to return for store credit.
- jhdez317Jun 18, 2021Tutor
so, I was working on moving my game room upstairs and I unplugged power to the router. When I plugged it back in the networks name changed to Netgear and Netgear-5G, some weird stuff man. So i had to do a factory reset. looks like it is not letting me log in to DUMA OS/Configuration page. Im gonna keep it for now, one more chance, but man are these gaming routers finicky as hell.
- Netduma-FraserJun 19, 2021NetDuma Partnerjhdez317 it sounds like the sudden loss of power caused a partial reset, best way to counteract this is setup everything, then reboot the router from the interface. This will act as a hard save in the case that you need to unplug the router. The default admin / password interface details aren't working?
- jhdez317Aug 17, 2021TutorI ended up using the geek squad protection to return my nighthawk router and got a Linksys - Max-Stream AX6000 Mesh Wi-Fi 6 Router. It working great so far.
