SillyMo
Apr 30, 2021Tutor
XR1000 haserl CGI Error
Hello! I have an XR1000 that throws the following message when I try to log in to the admin page after rebooting the router. haserl CGI Error Failed to readline from 'config get DumaOS_Theme_V...
SillyMo
Jun 03, 2021Tutor
Do yourself a favor and return this POS. I've gone through 2 XR700s and now 3 XR1000s. They all exhibit the same DNS issue that Netgear has been working on for more than a year. The config issue you are running in to, is also a known issue that Netgear hasn't fixed either.
patrickbedgood
Jun 03, 2021Apprentice
Will a replacement resolve or move away from this model router?
- Netduma-FraserJun 03, 2021NetDuma PartnerThe haserl error should be resolvable via TFTP, if not then a replacement should resolve it yes
