SillyMo
Apr 30, 2021Tutor
XR1000 haserl CGI Error
Hello! I have an XR1000 that throws the following message when I try to log in to the admin page after rebooting the router. haserl CGI Error Failed to readline from 'config get DumaOS_Theme_V...
SillyMo
Aug 16, 2021Tutor
After sitting without issues, this is now happening again.
I tried to log in to the router and i get the same hasserl CGI error I did before. :-(
Netduma-Liam
Aug 17, 2021NetDuma Partner
What firmware version are you currently running? Netgear released a new firmware for the XR1000 a few days ago, have you updated to that automatically? You can find it here if not: https://www.netgear.com/support/product/xr1000.aspx#Firmware%20Version%201.0.0.58
Please ensure you factory reset after the upgrade!
