SillyMo
Apr 30, 2021Tutor
XR1000 haserl CGI Error
Hello! I have an XR1000 that throws the following message when I try to log in to the admin page after rebooting the router. haserl CGI Error Failed to readline from 'config get DumaOS_Theme_V...
SillyMo
Apr 05, 2022Tutor
Again with this error on a warranty replaced unit. This is beyond ridiculous. This is literally the 6th Netgear DumaOS router because they keep having issues.
After rebooting it, it decided to maser reset itself. Utter junk.
Run through setup. It seems to setup fine but doesn't detect an update, even though there is one Install update and now it does is say "Uncaught TypeError: $(...)[0].getApp is not a function." Seriously how does this keep getting worse?
Netduma-Liam
Apr 06, 2022NetDuma Partner
How did you reboot it? Using the button on the back or through the interface? I'd suggest doing it through the interface.
What firmware version is it currently running that you can't update from? You could also try download the latest firmware from support.netgear.com and manually do the upgrade.
