Dakine33
Jan 16, 2022Aspirant
XR1000 Having dhcp issues
XR1000 issues below screenshot. Hello Netgear Community, So I just got a XR1000. I'm upgrading from an XR450 and since I installed my new router I keep having issues in 2 devices assigni...
Dakine33
Jan 17, 2022Aspirant
How can I do that?
Jan 17, 2022Guru - Experienced User
- Dakine33Jan 17, 2022AspirantThanks I already did that, and it’s happening the same. They already have static ips and the log monitor is saying that it assigned dhcp.
Do I have a faulty router?- Netduma-FraserJan 30, 2022NetDuma PartnerYou'll need to assign them outside the DHCP range so whatever the highest number for the reserved IP you set, add 1 and set that as the starting number for DHCP
