NolanDeckard
Feb 21, 2025Tutor
XR1000 having problems with Playstation 5 in Rest Mode
Hello, Just curious if anyone has any ideas about what could be causing a potential issue with my XR1000 and my Playstation 5. My XR1000 has no connection issues with my console when it is tu...
NolanDeckard
Feb 21, 2025Tutor
I'd be surprised if it is a Sony issue, as it was happening with my standard PS5 before I upgraded to the Pro recently.
https://www.reddit.com/r/PS5/s/1Sm7K5R4Cz
I had a read through of this earlier and alot of people facing the same issue, but nobody seems to have any definitive conclusions on what might be causing it.
Netduma-Fraser
Feb 21, 2025NetDuma Partner
Try disconnecting the ethernet and connecting it via WiFi instead, does it work better then?
- NolanDeckardFeb 21, 2025TutorIt's a tricky one to replicate, as it needs to have an update go live when it's in Rest Mode.
I'll unplug the ethernet overnight, see what's happened in the morning and update here.
Cheers for the response!
