Rk88
Dec 26, 2023Follower
XR1000 Help
I had recently purchased the XR1000. Really wished I would have done a little more research before buying. I've been through multiple threads trying to fix these issues and nothing seems to help and ...
Dec 26, 2023Guru - Experienced User
Do you have the v1 or v2 version of the XR1000?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? MS Edge or Firefox is recommended.
Be sure to clear out all browser caches before entering the routers web page.
What WiFi devices are you connecting?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
I've had XR1000 online before for over two weeks. Solid router and solid operation. Thought mines a v1 model and not a v2. Not sure about a v2 though shouldn't be too much difference.
