Rk88
Dec 26, 2023Follower
XR1000 Help
I had recently purchased the XR1000. Really wished I would have done a little more research before buying. I've been through multiple threads trying to fix these issues and nothing seems to help and ...
Netduma-Fraser
Dec 27, 2023NetDuma Partner
In addition to the above are you using Armor? Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 4 minutes before accessing and see if it works better then please.
