Rk88
Dec 26, 2023Follower
XR1000 Help
I had recently purchased the XR1000. Really wished I would have done a little more research before buying. I've been through multiple threads trying to fix these issues and nothing seems to help and ...
Jan 04, 2024Guru - Experienced User
Any progress on this?
Rk88 wrote:
I had recently purchased the XR1000. Really wished I would have done a little more research before buying. I've been through multiple threads trying to fix these issues and nothing seems to help and apparently I'm not the only one with these problems, so I'm only left to assume this product is straight **bleep** and hoping someone could help change that.
Router worked well as far as I know for like a day. After that I cannot connect to Dumos at all. I've had to reset and input SN about 15 times because it does not recognize anything and will not connect to the router even though some Wi-Fi equipment still gets internet, but not all. cuts out when ever it feels like it. Cant use any of the features correctly except for the ping.
I have updated the Firmware, I've reset everything multiple times, I ran with and without my VPN incase that was the issue. I've tried everything I could think of to get this to run correctly. At max I've gotten a day of solid Wi-Fi then straight garbage after that. certain programs wont even work and tell me I have no internet when I am getting it on other devices that aren't hardlined in that exact moment with no issues.
If anyone has any kind of ideas that I haven't tried yet it would be greatly appreciated before this thing turns into a 300$ paperweight.
