PapaLung
Nov 07, 2022Apprentice
XR1000 High upload ping
I know I have asked a similar quesiton about ping and using the connection benchmark and the QOS settings to adjust ping but there's been a few changes in my setup since as well as some new developme...
- Nov 07, 2022
PapaLung wrote:
I know I have asked a similar quesiton....
Did you ask it in the appropriate section?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
You might like to search there for messages related to your problem.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Netduma-Fraser
Nov 12, 2022NetDuma Partner
Interesting, did anything appear blocked on the map when you were doing the speedtest?
PapaLung
Nov 12, 2022Apprentice
Not that I noticed but I will test it with the xbox added, filter off and on to see. I still have an issue where servers that should be in the states are showing in England. I can start a new question thread on that if needed, I have a few questions regarding the geofilter I'd like answered if possible.
