mtabikha
May 29, 2023Aspirant
XR1000 Hybrid VPN
Hello, I last checked September last year and was told that the hybrid VPN feature was most likely in the works of a firmware update. Is there any update?
Netduma-Fraser
May 30, 2023NetDuma Partner
You should see it in the next version I believe
- TheDictatorAug 11, 2023AspirantNo Hybrid VPN in new firmware update?
- Netduma-FraserAug 11, 2023NetDuma PartnerThat was just a security update from Netgear, the one from us will have it available
- W1ZZK1D12Nov 01, 2023Aspirant
Can you elaborate on this. This is crazy, how is this the flagship and it hasn't been resolved?
