mtabikha
May 29, 2023Aspirant
XR1000 Hybrid VPN
Hello, I last checked September last year and was told that the hybrid VPN feature was most likely in the works of a firmware update. Is there any update?
TheDictator
Aug 11, 2023Aspirant
No Hybrid VPN in new firmware update?
Netduma-Fraser
Aug 11, 2023NetDuma Partner
That was just a security update from Netgear, the one from us will have it available
- W1ZZK1D12Nov 01, 2023Aspirant
Can you elaborate on this. This is crazy, how is this the flagship and it hasn't been resolved?
- Netduma-FraserNov 02, 2023NetDuma PartnerIt's not an issue that needs to be resolved, it's a separate feature we developed and the XR1000 didn't have it to start with. It's also not our decision as and when features are provided. However, the beta update for 3.3 shouldn't be much longer and I believe it will have HybridVPN added.
