wakkoroti
Mar 27, 2021Guide
XR1000 Internet Drops on WiFi only
The internet loses connection intermittently for devices that are connected via WiFi on the router. When it happens, clients that are connected via LAN have no issues. Clients connected via WiFi are ...
- Apr 07, 2021
It has now been a week and turning off iOS Private Address for both 2.4 and 5ghz networks AND reserving an IP address for any iOS device as made the router happy. I kept the release version of firmware on the router.
Netduma-Fraser
Mar 27, 2021NetDuma Partner
Could you disable Smart Connect for WiFi please and manually connect devices to 2.4/5GHz and see whether it resolves the issue please?
- wakkorotiMar 27, 2021Guide
I don't use smart connect. I only use it as two separate networks already.
- Netduma-FraserMar 28, 2021NetDuma PartnerDo you have any wireless devices e.g. headphones, remotes or electrical devices within 3 feet of the router? If so move them away if possible and see if it continues please.
- wakkorotiMar 28, 2021Guide
No devices are close.
Problem suddenly started when I returned home from a long trip. Was working fine for my partner for months. When I arrived home, bringing 5 devices back to the network with me that all use WiFi, the problem started.
