wakkoroti
Mar 27, 2021Guide
XR1000 Internet Drops on WiFi only
The internet loses connection intermittently for devices that are connected via WiFi on the router. When it happens, clients that are connected via LAN have no issues. Clients connected via WiFi are ...
- Apr 07, 2021
It has now been a week and turning off iOS Private Address for both 2.4 and 5ghz networks AND reserving an IP address for any iOS device as made the router happy. I kept the release version of firmware on the router.
wakkoroti
Mar 27, 2021Guide
I don't use smart connect. I only use it as two separate networks already.
Netduma-Fraser
Mar 28, 2021NetDuma Partner
Do you have any wireless devices e.g. headphones, remotes or electrical devices within 3 feet of the router? If so move them away if possible and see if it continues please.
- wakkorotiMar 28, 2021Guide
No devices are close.
Problem suddenly started when I returned home from a long trip. Was working fine for my partner for months. When I arrived home, bringing 5 devices back to the network with me that all use WiFi, the problem started.
- Netduma-FraserMar 28, 2021NetDuma PartnerWhat are the specific devices that you connected? If you make a guest WiFi network and connect those devices to it does that prevent it happening on the main WiFi?
These were devices that were working on this network prior to my trip, but they are:
iPhone 12
iPhone 7
MacBook Pro
Surface Pro 6
Apple Watch 4
iPad Pro
I'll try the guest network option. On a device that wasn't working, I did try changing to the 2.4ghz network and it still didn't work. It's largely intermittent but seems to have to be related to multiple clients in use. Last night was streaming to a LAN connected AppleTV and trying to surf on iPad and both devices started losing connection. When I disconnected the iPad from the wifi, the AppleTV resumed its connection.
