FeaRzFPS
Jul 16, 2023Tutor
Xr1000 internet works but constant flashing amber light
So basically I have BT 900mbps internet. My connection is PPOE. Everytime i turn the router on or off I have to manually setup the router everytime. Creating password etc and it’s odd. But right now t...
Netduma-Fraser
Jul 16, 2023NetDuma Partner
Good advice above, you're having to re-do everything as you're unplugging it and haven't done a reboot from the interface first which acts as a hard save, do that after you've changed settings and it shouldn't happen again.
FeaRzFPS
Jul 16, 2023Tutor
i rebooted from the settings as you said and it directly took me to the setup page to set up again
- Netduma-FraserJul 16, 2023NetDuma PartnerWhen you finish the setup wizard and go through to the main interface have you changed any settings? If not do that, reboot from the interface, then wait a few hours or so before unplugging it - if you're trying to reboot either doing so from the interface or using the button on the back is best.
