FeaRzFPS
Jul 16, 2023Tutor
Xr1000 internet works but constant flashing amber light
So basically I have BT 900mbps internet. My connection is PPOE. Everytime i turn the router on or off I have to manually setup the router everytime. Creating password etc and it’s odd. But right now t...
Netduma-Fraser
Jul 16, 2023NetDuma Partner
Good advice above, you're having to re-do everything as you're unplugging it and haven't done a reboot from the interface first which acts as a hard save, do that after you've changed settings and it shouldn't happen again.
FeaRzFPS
Jul 28, 2023Tutor
this is not correct. My router does not hard save anything. every time i turn it off or perform reset or unplug i have to set it up as new router every time. I have had my router installed now for over a week and i have internet but the power light is always flashing amber. i am on the XR1000 1.0.0.68_1.0.54 update which is the latest one. i cant access geo filter on app as it said cant sync cloud. if i turn off router and back on, it will set up completely, nothing hard saves. There is defo a problem with my router.
- FeaRzFPSJul 28, 2023Tutor
my isp is BT and i use a PPoe connection. i connected the dsl cable from the BT ont to the internet/wan port on my NG. is this correct? something just isnt right. i have internet connection but cant use the features i wanna use
- Netduma-FraserJul 29, 2023NetDuma PartnerJust to clarify, once you change settings you have rebooted the router from the interface?
You said a DSL cable, do you definitely mean a DSL cable (RJ11)? If so, you have the correct port on the XR but it needs to be an ethernet cable (RJ45) that connects to the ONT and would explain why you can't use the features properly.- FeaRzFPSJul 29, 2023Tutor
yeah i mean ethernet cable from the BT ONT to the NG.
