FeaRzFPS
Jul 16, 2023Tutor
Xr1000 internet works but constant flashing amber light
So basically I have BT 900mbps internet. My connection is PPOE. Everytime i turn the router on or off I have to manually setup the router everytime. Creating password etc and it’s odd. But right now t...
Netduma-Fraser
Jul 29, 2023NetDuma Partner
Make your settings changes, then leave it completely for 2 hours, reboot from the interface, top right rather than though the settings pages then check, has it still reverted?
FeaRzFPS
Jul 30, 2023Tutor
Yes it still reverts
- Netduma-FraserJul 30, 2023NetDuma PartnerDo you have the router connected to a power extender or direct to an outlet? If an extender could you do an outlet, repeat the process above and see if it works please?
- FeaRzFPSJul 30, 2023TutorIt is plugged directly into the outlet.
