FeaRzFPS
Jul 16, 2023Tutor
Xr1000 internet works but constant flashing amber light
So basically I have BT 900mbps internet. My connection is PPOE. Everytime i turn the router on or off I have to manually setup the router everytime. Creating password etc and it’s odd. But right now t...
Netduma-Fraser
Jul 30, 2023NetDuma Partner
Do you have the router connected to a power extender or direct to an outlet? If an extender could you do an outlet, repeat the process above and see if it works please?
FeaRzFPS
Jul 30, 2023Tutor
It is plugged directly into the outlet.
