FeaRzFPS
Jul 16, 2023Tutor
Xr1000 internet works but constant flashing amber light
So basically I have BT 900mbps internet. My connection is PPOE. Everytime i turn the router on or off I have to manually setup the router everytime. Creating password etc and it’s odd. But right now t...
Netduma-Fraser
Jul 30, 2023NetDuma Partner
I think you may have a faulty unit then, I can't see any other reason so far as to why it would be resetting every time you reboot. Depending on warranty it may be best to pursue a replacement with Netgear directly or exchange it with the retailer you purchased it from.
FeaRzFPS
Jul 30, 2023Tutor
I thought that would be the case, I have raised this with netgear, thanks for your help
