jdtime
Jan 02, 2021Aspirant
XR1000 IPV6 DNS Not saving
Anyone else seeing since firmware .50 and 52. If you try to set your own ipv6 dns server it looks like it saves but ones you log off and log in again its changed to your isp dns server. Happens loggi...
Netduma-Fraser
Jan 03, 2021NetDuma Partner
Could you disable QoS entirely from the Congestion Control 3 line option menu please and then change the IPv6 options, does it stay saved?
jdtime
Jan 03, 2021Aspirant
I actually disable qos when I set up the router as I dont use that feature. I know when I reload on .43 firmware and factory reset and set it up from scratch it saves the ipv6 no problems. Built .50 and .52 wont save even after another factory reset and I set up the router from scratch. Wont save even if it was working in .43 and upgrade firmware without doing a factory reset it changes the dns numbers to the isp and its pulling that dns address by itself. I check it and it is comcast dns numbers.
Any idea on the dropping ipv6 connection unless I switch between some of the settings as well?
- Netduma-FraserJan 03, 2021NetDuma PartnerCould you try setting it all from this link instead please? It's a link direct to the settings so DumaOS doesn't play a factor. If it does work then something we need to look into, if it doesn't then something for NG to look at http://routerlogin.net/adv_index.htm
- jdtimeJan 03, 2021Aspirant
Nope that doesnt work either. Looks like it saves for a bit then log back in and its changed to the ips dns. Something with NG firmware side of things I guess.
