JJdubbs77
Apr 07, 2022Aspirant
XR1000 ISP model replacing ISP firmware with Netgear stock firmware
Hi I have an XR1000 Nighthawk router supplied by RCN ISP and I noticed that it's running 2 year old firmware version and some of the filtering features aren't working properly. I'm wondering is there...
Netduma-Fraser
Apr 07, 2022NetDuma Partner
I don't think you'll be able to do that unfortunately. I'm checking with the team in regards to updates for the ISP models. I suspect that the ISPs may not want to update too often, if there was a major issue for example it would affect a lot of people.
What are the filtering issues you're having specifically?
- JJdubbs77Apr 07, 2022Aspirant
Hi thanks for the reply. Sometimes the filtering doesn't work and I have to manually remove and re-add the device to get it working. After a few tries it works.
I read online someone suggested updating the firmware but since mine is almost 2 years old I figured if there's a way to switch to stock Netgear firmware it would work better on a newer firmware. So there's definitely no way to do this?
- Netduma-FraserApr 07, 2022NetDuma PartnerDo you enable the filter after the game is on as that could explain it, it's best to have it enabled before you start the game so it can filter correctly.
There is no way that I am aware of unfortunately.
