Blarn_Kranston
Sep 06, 2022Apprentice
XR1000 Issues Constant Crash
Has any resolution been posted for this? I have reloaded the firmware via tftp, reset to factory default multiple times, I do NOT run Netgear Armor and yet I am still looking at this error RIGHT NOW...
Sep 07, 2022Guru - Experienced User
Try and enable IPv6 for the internet connection and set it to Auto. Then see if you continue to have web page problems or not.
Blarn_Kranston wrote:
Hi Furry,
The only IPV6 setting I see is related to the internet connection itself, which is disabled. Is there somewhere else in DumaOS it is configured for local devices?
Blarn_Kranston
Sep 07, 2022Apprentice
Done and applied. Also made the changes Fraser suggest to the RAPPs.
- FURRYe38Sep 08, 2022Guru - Experienced User
Let us know how it operates after a while...
- Blarn_KranstonSep 20, 2022Apprentice
So far, so good. The web interface is still buggy and slow to respond, but I have not rebooted the router since my last post (not including the random power outage that happens where I live every so often). I will post here if anything changes.
Thanks again for all your advice Furry.
- Netduma-FraserSep 20, 2022NetDuma PartnerDid you clear the browser cache/cookies and reload each page to see if it speeds it up? Glad to hear it's improved overall.
