Maschera
Jul 26, 2024Aspirant
XR1000 issues
I have an XR1000 product. (v1) I am using the latest firmware, and I have installed it 2-3 times to address my issues, but this action has not provided a solution. I have read the documents fo...
Jul 26, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What do you mean by wifi connection drops?
What devices do you have all connected to the router?
How many devices are connected?
What WiFi channel configuration do you have set on the router under basic and advanced sections?
NG routers don't test to block HTTPS sites or social apps. You should look into some DNS services like OpenDNS or NextDNS for help in blocking apps or services.
Maschera
Turk Telekom / Huawei HG8010H.
-I'm using UGREEN Cat 8 sleeved cable.
-This means that the Wi-Fi is connected, but my phone and other devices show a 'no internet' warning. If we don’t turn the settings off and on again, the internet won’t work. This doesn’t happen very often, but we experience it from time to time.
-Smartphones.
-7.
-Default settings.
-None.
-What is the purpose of this feature then?
- FURRYe38Jul 26, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.-I'm using UGREEN Cat 8 sleeved cable.
-Smartphones.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHow many devices are connected?
-7.What WiFi channel configuration do you have set on the router under basic and advanced sections?
-Default settings.
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.Any Wifi Neighbors near by? If so, how many?
-None.NG routers don't test to block HTTPS sites or social apps. You should look into some DNS services like OpenDNS or NextDNS for help in blocking apps or services.
-What is the purpose of this feature then?If you set an IP address reservation for devices you want to block, does this change the behavior?
Be sure to disable Mac Address Randomizers on the phones.
