Maschera
Jul 26, 2024Aspirant
XR1000 issues
I have an XR1000 product. (v1) I am using the latest firmware, and I have installed it 2-3 times to address my issues, but this action has not provided a solution. I have read the documents fo...
Maschera
Turk Telekom / Huawei HG8010H.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
-I'm using UGREEN Cat 8 sleeved cable.
What do you mean by wifi connection drops?
-This means that the Wi-Fi is connected, but my phone and other devices show a 'no internet' warning. If we don’t turn the settings off and on again, the internet won’t work. This doesn’t happen very often, but we experience it from time to time.
What devices do you have all connected to the router?
-Smartphones.
How many devices are connected?
-7.
What WiFi channel configuration do you have set on the router under basic and advanced sections?
-Default settings.
-None.
NG routers don't test to block HTTPS sites or social apps. You should look into some DNS services like OpenDNS or NextDNS for help in blocking apps or services.
-What is the purpose of this feature then?
Jul 26, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.-I'm using UGREEN Cat 8 sleeved cable.
-Smartphones.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
-7.What WiFi channel configuration do you have set on the router under basic and advanced sections?
-Default settings.
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
-None.NG routers don't test to block HTTPS sites or social apps. You should look into some DNS services like OpenDNS or NextDNS for help in blocking apps or services.
If you set an IP address reservation for devices you want to block, does this change the behavior?
Be sure to disable Mac Address Randomizers on the phones.
- MascheraJul 26, 2024Aspirant
I will try your suggestions. Thank you for your help.
- FURRYe38Jul 26, 2024Guru - Experienced User
I'll check my XR1000v1 out with the block controls as well since I currently have it online as well. I don't use blocking controls much as house hold is all adults here. 😉
- Netduma-FraserJul 26, 2024NetDuma PartnerIf you get the disconnect again grab the logs from the System Information page and upload it here, that will tell us more.
- FURRYe38Jul 27, 2024Guru - Experienced User
Noticed trying to run the Connection Benchmark on 1st try, speed was not to spec for a 1Gb/50Mbps ISP serivce. Download was around 300Mbps. Upload was fine. I disabled the Scheduling of speed tests from the setting menu is all.
I then logged off the routers web page and logged back in a 2nd time and re-ran the speed test again twice and both times the sped was now to spec on the download and over 900Mpbs. MS-Edge browser in Win11.
Blocking of web sites is not working.
