Schuff
Jul 07, 2023Aspirant
xr1000 just lost all settings and wont load duma
So I reset my router and after it came back online DumaOS just doesn't load, the router Wi-Fi names reverted back to "netgear 2.4 and netgear 5" instead of what they had been named. When i go to load...
Netduma-Fraser
Jul 08, 2023NetDuma Partner
When you factory reset you will lose all settings that is normal. Reboot the router but wait 2 minutes before you attempt to access, then try accessing via 192.168.1.1 instead of routerlogin.net and see if that works.
Schuff
Jul 09, 2023Aspirant
When i do that it says 404 not found,
- Netduma-FraserJul 09, 2023NetDuma PartnerIt might be that it's using 10.0.0.1 instead, see if that works
